Hello Guest it is November 24, 2026, 07:08:43 AM
Author Topic: looking for a circular pocket wizard video  (Read 21848 times)
« on: December 04, 2011, 10:58:05 PM »
trying to learn how to cut a circular pocket with a wizard.
I already almost crashed my machine because some of the wizards are metric... didn't like that.
viewing a video would be a big help, searched youtube and couldn't find one... or any video of a wizard use may be a big help
Re: looking for a circular pocket wizard video
« Reply #1 on: December 05, 2011, 12:48:32 AM »
What is exactly the "X center" and "Y center"
Let's say I have my cutter positioned exactly over the center of where i want to make my circular pocket. Do I just leave these at "0"?
When I preview the wizard it looks like the X and Y move before it starts cutting pocket
« Reply #2 on: December 05, 2011, 04:50:40 AM »
X and Y center is the location of the circle relative to where the center of the cutter is. Thus if they were both zero you would be exactly over the center of the circle
and there would not be a rapid move to the center of the circle. Now if you were use say x &y =2 you would see a rapid move to the center.
One thing to remember  or always check is your current location shown in Mach ....before...... you use the wizard.  If the x & y DRO shows their location to be 2 then even if
you used zero for the X&y center in the wizard you would see a rapid move to the center of the circle.
I think this is why you are seeing the move.
« Reply #3 on: December 05, 2011, 06:09:23 AM »
I think all wizards can be set to metric or imperial, if you look there will be a button to change.
« Reply #4 on: December 05, 2011, 10:24:07 AM »
I had loaded a non NFS wizard, it didn't have inch/metric option like NFS.
So I just put in small metric dimensions for an air cut run. Z tried to go 100mm up (actually 100")... When everything was supposed to start at zero... Z just homed rapidly.. then looked at gcode and saw mistake.
Is absolute or incremental preferred for NFS wizards? Isn't there a Mach checkbox for this?
« Reply #5 on: December 05, 2011, 10:26:59 AM »
What wizard is that?
Absolute is the norm.
« Reply #6 on: December 05, 2011, 11:02:09 AM »
New fangled solutions, circular pocket.
« Reply #7 on: December 05, 2011, 11:29:20 AM »
After choosing the circular pocket option from Newfangled Wizards menu, under "Tool Properties" which is the first page to input data, there is a choice right next to "Tool Unit" of Millimeters or Inches.
« Last Edit: December 05, 2011, 11:31:45 AM by budman68 »
« Reply #8 on: December 05, 2011, 11:40:26 AM »
Budman, the NFS ones are good. It was a wizard by another guy that was purely metric.
I swear there was a wizard bid out there, I just need to view a vid to start me out right.
« Reply #9 on: December 05, 2011, 05:01:15 PM »
Just take the time to play with the wizards and see how they work.
Practice makes perfect..........
