Hello Guest it is November 22, 2026, 08:36:06 AM
Author Topic: Initialization problem  (Read 12398 times)
« on: December 03, 2011, 01:06:25 AM »
I have G28.1 X0Y0 command in general settings screen set, to init the axis when I first start MACH3.
It works, BUT before execution of this command, the machine automatically goes high speed to it remembered machine zeroes.
This makes some problems if I move manually the spindle head, when the machine is powered off.
How to turn this OFF?
Thanks!
Re: Initialization problem
« Reply #1 on: December 03, 2011, 03:36:53 AM »
What exactly are you trying to achieve?
If wanting to simply automatically reference to your home switches on startup then its probably best to do it via a macro.
« Reply #2 on: December 03, 2011, 08:00:14 AM »
Exactly, and how should this macro looks?
« Reply #3 on: December 03, 2011, 08:31:19 AM »
If you want all axis to home at once then the macro would be
RefCombination (7)
If you wanted say the Z first then X and Y together it would be
DoButton 24
RefCombination (3)
You would then save as a macro with a number over 100, so for example if you dont already have a macro called m101 you could use that. Just save it to your profiles macro folder as m101.m1s
Then put m101 in the initialisation string.
« Reply #4 on: December 06, 2011, 05:13:22 AM »
Thanks! It works! :-)
« Reply #5 on: December 06, 2011, 06:41:41 AM »
Glad to hear it :)
