Hello Guest it is November 22, 2026, 07:59:48 AM
Author Topic: Laser trigger Output Family  (Read 10398 times)
« on: December 02, 2011, 11:01:48 PM »
I have a Wenglor height sensor HN 24 MGV, that will give me a height measurement based on a 0-5v signal. I want to use this in conjunction with the laser trigger output family, to get a point cloud xyz measurement. I am thinking that I can log height (Z) by capturing the the signal from the Wenglor sensor, but need to combine this with x and y location. I use Rhino so once I have values I can input direct into Rhino to generate point cloud scans of any object that will fit on my machine. Does anybody have any ideas on how I can capture and combine.
  •  9,378 9,378
Re: Laser trigger Output Family
« Reply #1 on: December 05, 2011, 06:59:34 AM »
Hi Dave,
I am not aware of anyone using these analogue type of sensors (they are usually binary) so you may be pioneering new ground here. Interesting devices nonetheless and I would be most interested in hearing how you proceed.
« Reply #2 on: December 05, 2011, 06:55:09 PM »
Long ago I tested a routine that used a laser rangefinder.  You can do it as a probe routine but not as an on the fly routine. The Mach interface is not fast enough at 10hz.
You would need an analog to digital convertor to get a value into mach. Or a simple PLC maybe
Then use the G31 routine and let a set value from the LRF trip the G31 then use the Z axis value as the height offset.
That way you can use the XYZ Points generation M40/41) to create the Pointsfile as an auto function (no extra programming needed) and very dependable.
It worked very well back then but teh unit I tested with was not that accurate(lowbuck) just did it to test teh theory.
Just a thought, (;-) TP
