Hello Guest it is November 04, 2026, 02:59:31 AM
Author Topic: Mach test problems  (Read 7814 times)
Mach test problems
« on: November 30, 2011, 10:29:59 AM »
Just starting up, going through manual step by step. Got to the try teach, typed in the code, stop teach, load/edit, go to Program runscreen. When I hit cycle start, it does nothing. If I hit it a scond time it jumps to the last line of code. Typed the code for a rectangle right from the manual. ???
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Mach test problems
« Reply #1 on: November 30, 2011, 11:00:54 AM »
Hi Kart - welcome to the forum
try adding in these two lines at the end of the program
M30 (program end and rewind)
% (comment to make sure there's a carriage return terminitor at the end of file)
Ian
« Last Edit: November 30, 2011, 11:03:07 AM by stirling »
