Hello Guest it is November 13, 2026, 09:34:26 AM
Author Topic: random number on dro  (Read 12756 times)
« on: December 23, 2006, 12:22:27 PM »
hi to all, i have a question:
at start of mach3 the display of the quote of axis report a casual numbers
is possible running mach3 with all the display at 0.0000 ?
sky the picture at example
Franco
Re: random number on dro
« Reply #1 on: December 24, 2006, 10:52:02 AM »
Franco
 not clear what you are asking, sorry.
 Do you have home switches on your machine? Do you reference it?
 What you have shown in the pic is that you have not referenced (homed) the machine.
« Reply #2 on: December 24, 2006, 09:37:36 PM »
There is a setting under the Configs that will set the DRO's to zero on startup...
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #3 on: December 26, 2006, 01:33:40 AM »
Hi Brian,
sorry for my novice in mach3,
 i not find "DRO's to zero on startup"
please help me ?
thank you
Franco
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: December 26, 2006, 07:09:08 AM »
Hi, Franco
Click on Config (top left) select General Config..., Bottom right, UN-Check, Perisistent DRO's, then OK.
Close Mach3, then Restart Mach3, should show x0000, y0000 z0000, on start-up
Hope this Helps, Chip
