Hello Guest it is November 22, 2026, 02:24:45 PM
Author Topic: Hole drilling with tool compensation  (Read 8590 times)
Offline tomi
  •  11 11
« on: November 29, 2011, 02:46:37 PM »
No I'm deep in to the s**t...
I need example how to use tool compensation to drill hole. I have 16 mm diameter tool and I need drill different size holes 18, 20 and 22 mm. I need to use G41 or G42 code to compensate tool because tool size could be change.
Re: Hole drilling with tool compensation
« Reply #1 on: November 29, 2011, 06:28:38 PM »
You would NOT use G41/42 for drilling holes. THe only tool comp that comes into play with drilling holes would be tool length comp G43.
