Hello Guest it is October 23, 2026, 06:17:07 AM
Author Topic: Our own CNC related Black Friday Sale  (Read 36002 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« on: November 25, 2011, 09:49:31 AM »
We have two items with substantial savings for this special sale. You can only use one coupon code per order and the sale is limited to the first 20 sales of each item.
The first item, the venerable http://www.soigeneris.com/Gecko_G540-details.aspx: Only $225 only through Monday the 28th.
The G540 Use coupon code F187JD
The second item, our EZ-MPG-M1http://www.soigeneris.com/EZ_MPG_M1-details.aspx: Only $12.50, thats 50% off! The EZ-MPG-M1 is an easy way to add feed rate or spindle speed over ride controls to your machine. They come with a special plug-in for Mach 3 that gives you proportional type control (kind of like how a mouse works). This gives you really fine control when you rotate the know slowly and when you turn the know faster you get a much faster change.
EZ_MPG_M1 Use coupon code U2RSKX
Happy machining , Jeff Birt
Re: Our own CNC related Black Friday Sale
« Reply #1 on: November 25, 2011, 03:16:37 PM »
Jeff, the user manual download link is not working on the EZ MPG page.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: November 25, 2011, 03:43:05 PM »
Thanks for the heads up Dave. It is working now :)
« Reply #3 on: November 25, 2011, 03:57:32 PM »
