Hello Guest it is November 01, 2026, 01:43:31 PM
Author Topic: Macro integration problem  (Read 10865 times)
« on: November 25, 2011, 08:57:57 AM »
I have machine, that will drill holes, so it only uses X axis, and the drill is performed by pneumatic valve, that has sensors for up, and down positions.
I mapped them as INPUT1 and INPUT2.
The valve actuator is mapped to OUTPUT2.
So I wrote macro, (filename M123.M1S):
ActivateSignal(OUTPUT2)
while IsActive(INPUT2)=false
sleep(100)
wend
DeactivateSignal(OUTPUT2)
while isActive(INPUT1)=false
sleep(100)
wend
And the main g-code program looks like this:
m3
g0x100
m123
g0x150
m123
g0x300
m123
g0x350
m123
g0x500
m123
g0x550
m123
g0x0
m30
Basically, it works fine, but the problem is when I first load the g-code, mach3 starts to "Please wait. Generating path...", and hangs-up!
if I cancel it, then press e-stop, then release E-stop, somehow I am in the game, so I can start using this code.
So my question is why is that happening, and how to avoid it?
Thanks!
Re: Macro integration problem
« Reply #1 on: November 25, 2011, 09:30:27 AM »
Try this:
In General Config, in the General Configuration section, check the box "Ignore M Calls While Loading".
« Reply #2 on: November 28, 2011, 12:00:04 PM »
Thanks a lot! Now it is ok!
