Hello
Guest
it is
September 29, 2026, 07:13:47 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
Work offsetting difficulties using Offset screen and edge finder
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Work offsetting difficulties using Offset screen and edge finder (Read 8180 times)
Piper2010
8
on:
November 16, 2011, 04:41:45 PM »
I have a Sieg mill and Mach 3 running Ok but when I go to the Offset screen the documentation talks about the touch buttons and doesn't mention the select buttons. If I try and set G54 with an edge finder and enter the diameter of the edge finder, save the settings, then jog the axes away from the current positions then press goto zero on the program run screen the tool zeros to my required work offset origin but it has not allowed for the edge finder diameter. What am I doing wrong?
Logged
fixittt
290
Re: Work offsetting difficulties using Offset screen and edge finder
Reply #1 on:
November 21, 2011, 04:56:43 PM »
find the edge with your edge finder, Zero axis move Z up then move axis half the diameter of the edge finder, then rezero axis. Set g54 after compensating for half the dia. of the edge finder
Logged
Print
Pages:
1
Go Up
« previous
next »
