Hello Guest it is November 27, 2026, 09:41:44 AM
Author Topic: Shuttle v2 Mach3  (Read 28250 times)
Shuttle v2 Mach3
« on: November 14, 2011, 07:56:18 PM »
Hi
this is millguy
first time i post a question
I hook up a Shuttle v2 on Mach3 for my milling,every thing is ok
but try to program one button with custom macro #1
where is that custom macro #1 ?
How do i program it to have "Z+1
Thank
Re: Shuttle v2 Mach3
« Reply #1 on: March 30, 2013, 06:34:17 PM »
You have to create the macro.  The custom macro button calls the macro.
« Reply #2 on: March 31, 2013, 07:22:12 AM »
WHERE DO I WRITE THE''Z1.0''
IS THAT IN CONFIG/SYSTEM HOTKEYS EXTERNAL BUTTON OEM CODE
« Reply #3 on: March 31, 2013, 07:35:22 PM »
create a macro e.g.  m1234.m1s
in your profile macro folder e.g.   C:\Mach3\macros\Mach3Mill
config plug in ( see image )
the macro may look like this
Call Code("G0 Z1")
While ismoving()
Sleep 100
Wend
be careful
when you hit the button the Z axis is going to Z0 with rapid traverse
the same when you code m1234 in MDI or within your G code.
The Z0 position depends on your coordinate system setting
( G54 G55 G56 ....  G53 G52 G92 )
the safest choice is to use a fix position in G53 ( machine coordinates )
just a thought
Alex
« Reply #4 on: June 29, 2013, 09:12:17 AM »
HI
subject:shuttlepro V2 , custom macro #1
I applied the info to the computer in my office that is not hook up to a machine tool and the shuttlepro V2 button work ok
when i applied that to the milling machine and the lathe in the garage the custom macro #1 does not work
I get in mach3 screen  ''STATUS =custom macro executed #1 and it flashed red''
in mach3 the config/general config page is all the same on the 3 computer
the office and the lathe are windows professionel and the milling is windows famely
can you hep me
thank you
MILGUY
« Reply #5 on: June 29, 2013, 09:14:06 PM »
Hi Millguy,
try calling custom macro#1  in MDI line and see if it is working.
Maybe your macro is not in the right folder.
Alex
