Hello Guest it is November 13, 2026, 03:48:08 PM
Author Topic: Looses position when running a cycle  (Read 14938 times)
« on: November 14, 2011, 02:43:20 PM »
Hi, I have a CNC lathe that I converted to run on mach 3 but I'm having some issues with it. When I type in the G-codes manually one line at a time the lathe performs exactly as it should, but when I run a program it looses its place by quite a large amount - 10mm or so. I really need to get it sorted because manual machining is taking me too long. Help would be appreciated, thanks
Below is a bit of the code.
G21 G40
G00 Z5 X30
G01 Z0 F100
G01 X-2 F50
G00 Z5
G00 X25 Z2
G01 Z-38 F100
G00 X30
G00 Z5
M01
G00 X0
G00 X24 Z2   All ok until it gets to here, it only moves to about x12 but says x24 in software, I have to hit e-stop otherwise it would crash
G01 Z-38 F100
G00 X30
G00 Z5
M01
G00 X0
G00 X23 Z2 Does exactly the same here losing a further 10mm
G01 Z-38 F100
G00 X30
G00 Z5
Re: Looses position when running a cycle
« Reply #1 on: November 14, 2011, 04:09:59 PM »
Sounds like you may be looseing steps to me. Try detuning your accel and velocity by 50% and see if that helps.
« Reply #2 on: November 14, 2011, 05:06:06 PM »
Hi, If I type in all of this G code line by line then it does it all fine, when it is put all in one program it does not. I can type G0 Z0, Z500, Z0, X200, X0, X200 all in the manual command and it wont lose a single step, put this into a program and it will lose several hundred steps.
« Reply #3 on: November 14, 2011, 05:10:14 PM »
Can you attach your xml please, will see if I can replicate your problem here with your settings.
« Reply #4 on: November 14, 2011, 05:19:16 PM »
I will attach the xml tomorrow, software is on different computer to what I'm using at the moment.
« Reply #5 on: November 14, 2011, 05:22:37 PM »
Ok no problems getting late here anyway :)
« Reply #6 on: November 14, 2011, 05:41:17 PM »
Im thinking it may be loosing then when running in auto because you are changeing directions so fast.  I think inertia and accel are what you are fighting.
« Reply #7 on: November 21, 2011, 10:38:11 AM »
also you may try turning off the viewport.  this is an issue with very large g codes that i have run in the past,  now its standard practice to always turn off the viewport before pressing GO
