Hello Guest it is November 12, 2026, 04:19:09 AM
Author Topic: DIR Pulse  (Read 38251 times)
DIR Pulse
« on: November 12, 2011, 10:52:47 AM »
Hello,
Can anybody tell me, how long the DIR Pulse for the X,Y or Z takes "High" in mach3?
In Motor tuning is written down, that I can take a time between 1 and 5µs, but I can write down 7 or 8. is the signal then 7 or 8µs long or only 5µs?
I hope you understand my bad english
Greetings
Michael
Re: DIR Pulse
« Reply #1 on: November 15, 2011, 12:56:48 AM »
Hi Michael,
The values entered in those fields is the amount of time to be added to the standard pulse width (around 3uSec). So if you enter 5 there you will get an 8uSec pulse width. I think it is only true for the step pulse, the direction signal being just a change of state, but am not sure about this as some time ago someone was reporting a different behaviour (although with SmoothStepper) which was never confirmed by other users.
 If you need a wider pulse than that then use Sherline Mode (under Ports and Pins), which will give you around 20uSec pulse width.
Re: DIR Pulse
« Reply #2 on: November 15, 2011, 12:32:42 PM »
Hey
Oky thanks, that was it, i was looking for ;)
greetings
Michael
Re: DIR Pulse
« Reply #3 on: November 15, 2011, 05:13:31 PM »
Are you sure? I've never heard this before.
I believe Sherline mode is 40us pulse width.
Re: DIR Pulse
« Reply #4 on: November 16, 2011, 02:54:53 AM »
Hi Gerry,
I am only sure I remember Art or Brian mentioning it, but whether it's really the way it works I don't know.
Regarding Sherline mode, I am sure about it, as half the cycle time at 25Khz kernel is 20uSec ;)
