Hello Guest it is November 22, 2026, 07:12:58 PM
Author Topic: Allen Bradley Guru's  (Read 12028 times)
« on: November 12, 2011, 12:48:38 AM »
Doing some research on Allen Bradley AC servo drives. It appears to me that the -SE versions do not have step and dir inputs like the other models. Can anyone confirm this?
Re: Allen Bradley Guru's
« Reply #1 on: November 12, 2011, 03:10:56 AM »
The Sercos can be disabled on the DSD drives in Software or if its the DDM drives then you can remove the Sercos board. Doing that (at least in the DSD, not sure about DDM) will then turn the drive into a full indexing drive which gives you the advantage that you can use them to do the homing and thus get very accurate homing for your machine.
« Reply #2 on: November 12, 2011, 09:29:11 AM »
Thanks for the information. The drive I was looking at is the DSD drive. I don't see the STEP and DIR for SE model listed in the manual. So are you saying that if I disable the SERCOS option then the pin out changes to the non-SE version and STEP and DIR will be available?
« Reply #3 on: November 12, 2011, 10:20:32 AM »
Yes, I use quite a few of the Sercos drives and have the sercos disabled. If I recall when you look at the drive in Ultraware and right click on the first part of the tree you should see an option to disable Sercos.
« Reply #4 on: November 12, 2011, 11:26:18 AM »
Heres a couple of screenshots, first is a Sercos Drive about to have the Sercos disabled and the second is it after it has been disabled.
« Reply #5 on: November 12, 2011, 01:32:09 PM »
Great thanks for the info.
