Hello Guest it is October 24, 2026, 11:08:33 PM
Author Topic: thread mill only generates half the cut on od threading  (Read 15986 times)
« on: November 10, 2011, 08:00:35 AM »
Hello.
I have a newfangled wizard problem with threadmilling on the outside. I have used the wizard numerous times to generate G-code for internal cuts with no problems, but when trying to generate G-code for external threads it is only cutting half the length of the thread (half moon). I've copied the code that it generated and pasted it below.
Hope you can help!
(Code by Newfangled Wizard, 11/9/2011)
(Program Posted for Medium Steel )
G0 G49 G40.1 G17
G80 G50 G90 G98
G20 (Inch)
(***** Thread Milling *****)
M6 T5
M03 S1710.3
M8 (Flood On)
G00G43 H5 Z1
(Right Hand OD Climb)
X6.6385 Y2
G01 Z-0.3 F10.3
G01 X6.3035 F10.3
G02 X3.1965 Y2 R1.5535 Z-0.325
G01 X2.8615
G00 Z1
M5 M9
M30
Re: thread mill only generates half the cut on od threading
« Reply #1 on: November 11, 2011, 07:21:33 PM »
Can you tell me the parameters you used, or even better post a screen capture of the page. My guess is you have entered a parameter tomake the thread length less than the pitch, but Im only guessing
« Reply #2 on: November 13, 2011, 07:01:22 PM »
Thanks for trying to help. I got a little help direct from Machsupport. There was a bug in my Newfangled file. They refered me to another post on here
http://www.machsupport.com/forum/index.php/topic,16126.0.html...
I replaced my Newfangled file with the one provided in the link and all is good now.
Again, it's so good you wanted to help!!
