Hello Guest it is November 22, 2026, 11:15:17 AM
Author Topic: Latested 051 version charge pump problem  (Read 9325 times)
« on: November 09, 2011, 03:15:33 AM »
I have posted a similar post about this issue with version 50. This is still broken in my system.
The charge pump is not working with the version 50 and 51 (yestarday version). I run a couple more tests and found that it only works at 25KHz kernel.
Latest lockdown version have it working with all kernel speeds.
My set up is a C11 from CNC4PC driven from PCI parallel ports.
Filipe
Re: Latested 051 version charge pump problem
« Reply #1 on: November 09, 2011, 03:16:33 AM »
Also not sure if this is the right place to place bugs on testing versions. If not please correct me.
