Hello
Guest
it is
September 13, 2026, 07:03:50 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Can any Mach 2 screens or settings be used in Mach 3??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Can any Mach 2 screens or settings be used in Mach 3?? (Read 30108 times)
elalto
1
on:
November 01, 2005, 04:23:34 PM »
I have Mach 2 setup and running real well and have made up a couple of custom screens for my use, now I would like to go to Mach 3 and wondered if any of the settings, configurations, and screens can be used with M3.
Marcos (elalto)
Logged
ynneb
Re: Can any Mach 2 screens or settings be used in Mach 3??
Reply #1 on:
November 02, 2005, 12:40:56 AM »
The simple answer is no.
You cannot import the xml setup file from M2 to M3
You will also need to redo the screens, but you will be able to use the original BMP, JPGs etc
Unfortuanately its a non comfortable transfering process.
What I did was continue to use Mach2 for my production work and slowly set up Mach3 in my spare time.
Logged
David Morrow
38
Reply #2 on:
November 12, 2005, 01:15:26 PM »
I'm just getting things set up in Mach 2. Would you suggest just moving on to Mach 3 instead ?
Logged
David Morrow
Brian Barker
3,860
Reply #3 on:
November 12, 2005, 03:55:51 PM »
Go to Mach3 it is faster and it has better goodies
I have not run Mach2 in a VERY long time
Thank you
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
