Hello Guest it is October 24, 2026, 05:52:12 PM
Author Topic: Quick tool change question :)  (Read 12178 times)
« on: November 03, 2011, 04:00:55 PM »
Hello all. I have a 24 pocket tool changer that works GREAT, the only problem is my orientate sensor for the spindle crapped out on me. I need to make the machine work by putting the tools in by hand. Do I need to change the "Tool Change" in "General Config" to "Stop Spindle. Wait for Cycle Start"? Will this bypass my m6start macro?
Aero
Re: Quick tool change question :)
« Reply #1 on: November 03, 2011, 04:11:01 PM »
Yes that should just do as it says, stop and wait for start.
« Reply #2 on: November 03, 2011, 04:15:44 PM »
I don't think it will bypass the M6start it just waites for a MANUAL cycle start to run.
« Reply #3 on: November 03, 2011, 04:58:12 PM »
When Set to "Stop Spindle, Wait for Cycle Start", Mach3 runs the M6Start first, then stops and waits for Cycle Start, then runs M6End.
« Reply #4 on: November 03, 2011, 05:04:04 PM »
Yes just tested and it does indeed. Easy solution, rename your M6 macros and replace with standard ones until you get the orientation sorted.
« Reply #5 on: November 04, 2011, 11:11:18 AM »
Worked perfect!! Thanks guys :)
Aero
