Hello Guest it is November 24, 2026, 09:07:13 AM
Author Topic: G84 SRT  (Read 8196 times)
G84 SRT
« on: November 02, 2011, 12:31:55 PM »
Is there any configuration for the G84 tapping routine.  It doesn't have any type of dwell between the M4 and the Feed back out of the hole and it causes the tap to jump out at 0 Zed.
Richard
Re: G84 SRT
« Reply #1 on: November 02, 2011, 12:48:24 PM »
The G84 is correct for what it is (rigid tapping). IF you are using it with a floating tap holder then you must allow for the transition of the spindle from Cw to CCw. That way when the tap gets back to the top it does NOT have any spring load to it.(not always possible)
Also do not use it IF you are using spindle sync as the sync part is broken in mill ( last I used it) Turn OFF spindle sync and use the programed S speed.
IF you are doing tapping in MAch3 I would just setup a Tapping Sub and use variables to program it.  Works Everytime and you can specify feed and retract to account for the dwell.
« Last Edit: November 02, 2011, 12:52:14 PM by BR549 »
