Hello Guest it is October 26, 2026, 01:52:18 AM
Author Topic: Intermittent E-stops  (Read 11525 times)
« on: November 01, 2011, 03:57:35 PM »
Hi All,
I have a new Novakon NM200 that I have experienced two intermittent sudden E-stops and two sudden loss of power to the motors and spindle.  The NM200 has a Vista or 7 PC as the OS.  I run two other machines on Win XP and never experience this problem.  Two Estops had the message "Driver Watchdog triggered".  The machine is equipped with limit switches but I do not use them, nor was the table near the switches.  Also the motors were not being taxed at all when the E stops occurred (1 during retract, the other machining foam).  The two power downs did occurr while machining, the motors and spindle just stopped and I had to power down the pc completely to reset everything.  A real pain when machining a 3 hour part.
Novakon suggested uninstalling Mach3 which I did and installing the latest version (3.043.022).  But the sudden E-stops started happening.
For now I dissabled the limit switches in pins/ports because I don't really need them, I also unchecked the "enable driver watchdog".
BTW what is "Driver watchdog" and why would I want it?  What driver is it watching?
Any other troubleshooting suggestions?  ???
Thanks, Bob
Re: Intermittent E-stops
« Reply #1 on: November 01, 2011, 04:00:43 PM »
Turn OFF the watchdog it is not needed.
(;-)TP
« Reply #2 on: November 01, 2011, 04:21:16 PM »
Thanks, what is "driver watchdog"? -Bob
« Reply #3 on: November 01, 2011, 04:32:24 PM »
The watch dog is an enternal monitor that keeps a watch on things. On some systems it is TOO sensitive and will trip on things that do not effect Mach3 running properly.
« Reply #4 on: November 01, 2011, 05:37:16 PM »
Thank you for the reply.  Hopefully dissabling the watchdog will help.
