Hello
Guest
it is
October 16, 2026, 04:43:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Rotational milling speed?
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Rotational milling speed? (Read 37895 times)
bocada
Re: Rotational milling speed?
Reply #10 on:
December 20, 2006, 06:36:05 PM »
Genius! The checkbox worked!
Too many checkboxes...arg!
Thanks very, VERY much!
JQ
Logged
Chaoticone
5,624
Precision Chaos
Reply #11 on:
December 20, 2006, 06:37:11 PM »
If Graham doesn't know when it comes to Gcode it is because it hasn't been invented yet.
He helps gcode impaired folks on here a lot.
Logged
If you could see the things I have in my head, you would be laughing too.
Chaoticone
5,624
Precision Chaos
Reply #12 on:
December 20, 2006, 07:35:27 PM »
You're welcome. I love it when a plan comes together.
Logged
lemo
135
Reply #13 on:
May 07, 2007, 10:17:59 PM »
I have the same problem and the same setup except I need 320 as 1 degree factor. The check box only converts almost one step per second into a revolution per hour. Which is MUCH faster then a step per second, but still completely unacceptable. When I jog with G0 commands the A-Axis is very responsive with my 320 steps and 600Inch per second motor tuning. But the moment I use G1 the speed is gone and all goes downhill. The funny thing is that after I execute a single G1 A********* command subsequent G0 A********* commands are not fast any more. As if there is a flag which is set and not reset... or something.
Any ideas how that can be sped up? My new machine is all set up for action... only the @$%@$#@ A-Axis is ruining the fun.
Lemo
Logged
Cut five times and still to short...
Chaoticone
5,624
Precision Chaos
Reply #14 on:
May 08, 2007, 02:50:28 AM »
Hey Lemo,
Can you post your xml file here for us to see?
Logged
lemo
135
Reply #15 on:
May 09, 2007, 10:17:32 AM »
I tried another PC and oh wonder.... All problems vanished. All of a sudden the angular stepper behaves using the .0001 technique.
Only two minor issues remain. One is that the port finder utility does not work. The port however, is functioning just fine.
And I frequently (every 10-20 minutes) the system tends to run into a watchdog error. I disabled the watchdog and cannot see a problem visually.
When it hits the watchdog, the system freezes for a second, then continues as if there was nothing. For now I'm happy that all works. But I must say that Mach3 is working COMPLETELY different on three differen PC's. All P4's with 2GHz and better.
Thanks for all the comments!
Lemo
Logged
Jolines
7
Reply #16 on:
March 14, 2009, 10:34:37 AM »
I have Deskproto for generate the G-code for Microproto Dsls 3000. The 4 axis is slow, help me, please,, and always ''the predssed e-stop''
PLease help me...
thanks
Logged
Jolines
7
Reply #17 on:
March 20, 2009, 07:42:41 AM »
this method does works,,the speed is up,,, but when I'm working stops trigriss at 5 %,, please help
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #18 on:
March 21, 2009, 07:31:20 AM »
Are you getting an error message ?
If it is a watchdog error then in general config you can turn the watchdog off.
Graham
Logged
Jolines
7
Reply #19 on:
March 21, 2009, 07:58:58 AM »
yes,, limits switch triggered, and wathdog is on.
e-Stop 5 % , 25%
I used diameter for feedrate , 0.001 when the machine begins soon then for or but it follows and the low Z more must of it lower during the work and it damages soon it.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
