Hello
Guest
it is
November 22, 2026, 09:19:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Stepper amps and voltage
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Stepper amps and voltage (Read 10903 times)
nic6911
37
on:
October 25, 2011, 02:51:57 PM »
Hi everybody.
I have recently bought a couple of steppers and a Gecko G540, but I am not sure how many amps and volts my steppers should take. I have to add a resistor on the db9 connector on the gecko, the rated amp X1000 that is 2kOhm if the rated current is 2A.
If i got this right, it will take 4Amps when in parallel, and 2V X 20 = 40V - that means i will have to use a 3.5Kohm resistor as the gecko can only provide 3.5amps maximum and 40v? or should i use 48V?
Regards Nic
Re: Stepper amps and voltage
Reply #1 on:
October 25, 2011, 04:20:21 PM »
You may want to check out the Gecko site as they provide a lot of good information on their specific drives, power supplies, etc.
ger21
6,295
Reply #2 on:
October 25, 2011, 05:06:33 PM »
For Voltage, Gecko recommends 32* square root of inductance, which is about 40V.
As for amps, yes, set it for 3.5 amps. You'll lose about 12% of your torque, but it should perform better at higher speeds than if wired series at 2 amps.
nic6911
37
Reply #3 on:
October 26, 2011, 12:19:37 PM »
Hi.
Thanks for the reply. I have read the manual from Gecko, but i just want'ed to be sure.
thanks!
Print
Pages:
1
Go Up
« previous
next »
