Hello Guest it is October 17, 2026, 03:53:31 PM
Author Topic: Macro pump working...but not working  (Read 6954 times)
« on: October 24, 2011, 10:27:16 PM »
I know my macro pump is running, and it works as I should when I run it in the script editor - but I get no response from the part that turns on output 3...I've tried tying it to the output led, flood led...numerous different ways, but it only activates the output when I run it in the editor, the first half of the script controlling output 5 works fine...
'Gate Valve Vacuum Pressure Relief via button
If GetOEMLED(821) Then 'Button next to vac gauge
   If GetOEMLED(78) Then 'Output 5 led
      DeActivateSignal(Output5) ' Close vac valve
      Sleep(150)
      Else
                ActivateSignal(Output5) 'Open vac valve
           Sleep(150)
        End If
End If
If GetUSERLED(1225) And Not GetOEMLED(13) Then 'If dust hood override led on and flood led off then
   ActivateSignal(Output3) 'Raise dust hood
End If
Re: Macro pump working...but not working
« Reply #1 on: October 27, 2011, 03:11:43 PM »
Got it working...had to:
If GetUSERLED(1225) Then
If GetOEMLED(13) Then
Else
End If
End If
