Hello Guest it is November 22, 2026, 06:11:00 PM
Author Topic: Resetting home x and y after big crash.  (Read 12482 times)
« on: October 21, 2011, 01:30:29 PM »
I left my CNC running while doing some v-carving of text.  When I came back it was jammed in the back corner and digging into my tabletop big time.  I’m not sure what happened to make it cut almost 1 ½ “ deeper than it should have been cutting… shame on me for not watching it.   I can jog it fine but it thinks machine zero is out in the middle part of the cutting area.  Even though I re-zeroed the machine settings to the corner it still shows the bit location in the middle of my cutting area.  How do I get it reset?
Thanks!
Jim Williams
Re: Resetting home x and y after big crash.
« Reply #1 on: October 21, 2011, 01:38:19 PM »
Did you regen the toolpath?
« Reply #2 on: October 21, 2011, 01:41:45 PM »
Yes... regenerating doesn't change a thing... it still thinks the bit is in right field.
« Reply #3 on: October 21, 2011, 01:43:21 PM »
Could you be using a different offset from whats in the code?
If you attach your xml and code I will have a look.
« Reply #4 on: October 21, 2011, 03:40:30 PM »
False alarm!  I had set the toolpath to run from the center which I rarely ever do.  Thanks for the quick responses!
« Reply #5 on: October 21, 2011, 04:59:16 PM »
Thats good you got it :)
