Hello Guest it is October 21, 2026, 02:07:45 AM
Author Topic: Beginner question - Mach Input  (Read 14061 times)
Offline swbre
  •  11 11
« on: October 19, 2011, 08:18:58 PM »
I have installed the demo version of Mach3 on a PC and I have a breakout board connected to the printer port.  I want to connect an E-Stop switch as my next step.  In section 4.14 of the Mach3 Software Installation and Configuration Manual there is a sample schematic.  On the upper right hand of that schematic there is a line "To E-Stop Input".  My question is where do I connect that line on the breakout board?  Do I use one of the breakout board inputs, pins 10-13 and 15?
Attached is a picture of my breakout board.  Thanks to Chuck Hoelzen.
Stephen.
Re: Beginner question - Mach Input
« Reply #1 on: October 20, 2011, 01:03:10 AM »
Yes, just choose an input thats not presently being used then set that up as the E-Stop in Ports and Pins, Inputs.
  •  9,374 9,374
« Reply #2 on: October 20, 2011, 01:09:47 AM »
Stephen,
Connect the EStop wires, one to GND and the other to any spare input pin (pin 10 would be good). Then configure Mach / Ports and Pins / Input signals / EStop to Port #1, Pin 10.
Offline swbre
  •  11 11
« Reply #3 on: October 20, 2011, 07:11:22 AM »
It works.  I get an external Estop signal.  Yeah!
I only used the portion shown in yellow (on the attached) for experiment/trial purposes.
« Last Edit: October 20, 2011, 07:13:28 AM by swbre »
  •  9,374 9,374
« Reply #4 on: October 20, 2011, 07:28:39 AM »
Hi Stephen,
You are going to be an expert in no time  ;)
Glad you got it sorted.
Offline swbre
  •  11 11
« Reply #5 on: October 20, 2011, 08:38:07 AM »
I have no experience with connecting hardware to a PC so this is a good start.  Next I'll do some limit switches.
I noticed my Diagnostics screen has more information than what is shown in the manual (Mach3Mill_1.84_UserGuide.pdf) Appendix 1, Screenshot pullout.  I have something like Port 1 pin status LED indicators.  Has there been a revision to the system that didn't get included in the manual?
« Reply #6 on: October 20, 2011, 09:13:27 AM »
Mach is constantly evolving and trying to keep the manual up to date would be a very expensive thing to do, expensive in time for Brian as well as money, so afraid it is what it is.
Offline swbre
  •  11 11
« Reply #7 on: October 21, 2011, 10:56:13 AM »
I was wondering if there is any information on the Port 1 Pins current State area?  Why 24 Led's?  I would expect 25.  And why is the 4th LED lit when I have my E-Stop input tied to pin 15 on the breakout board?
Thanks for the replies and help.
Stephen
