Hello
Guest
it is
November 01, 2026, 10:06:59 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Want round but getting Square corner problems
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Want round but getting Square corner problems (Read 28348 times)
viperize
4
on:
October 19, 2011, 04:25:43 PM »
I was importing dxf files two days ago and if the file had a curve in it it would be a curve in Lazycam. But today when I import a file with curves in it I get square corners.
What went wrong? Is it in the setup on Lazycam?
Al
Logged
Re: Want round but getting Square corner problems
Reply #1 on:
October 19, 2011, 04:39:24 PM »
Post the probem DXF file.
Logged
viperize
4
Reply #2 on:
October 19, 2011, 04:43:27 PM »
How do I post a file?
Logged
Reply #3 on:
October 19, 2011, 04:49:12 PM »
Reply to this thread, then click preview, and you will see Additional Options,use the Browse to find the file you want to post.
Logged
viperize
4
Reply #4 on:
October 19, 2011, 04:51:33 PM »
Here is the file.
Logged
budman68
2,352
Reply #5 on:
October 19, 2011, 04:55:28 PM »
I resaved this dxf in VCarve Pro and exported into a dxf for you. Works fine now so I'm guessing it's the "type" of dxf you're saving it as. Try saving it as an 11 or 12 ACad version.
Logged
Dave->
viperize
4
Reply #6 on:
October 19, 2011, 05:07:15 PM »
Thanks That seams to work.
Logged
ger21
6,295
Reply #7 on:
October 19, 2011, 05:51:44 PM »
Your object is a spline, which LazyCAM (and a lot of other low end CAM) doesn't like. As Dave said, using v12 will convert the spline to a polyline.
Logged
Print
Pages:
1
Go Up
« previous
next »
