Hello Guest it is October 20, 2026, 02:56:14 PM
Author Topic: mach3 connect 2 Z axis  (Read 40778 times)
« on: October 18, 2011, 06:44:12 PM »
I just started to build cnc router with 2 Z axis , Please tell me how I connect the 2 Z axis to work separately. My  cnc driver  is g540
Re: mach3 connect 2 Z axis
« Reply #1 on: October 18, 2011, 09:15:58 PM »
Did you ever get a single axis to work correctly on your mill using the G540?  ???
Now your venturing onto a 4th / different machine.
« Last Edit: October 18, 2011, 09:23:28 PM by RICH »
« Reply #2 on: October 19, 2011, 06:27:17 AM »
not, it seems that it is not possible I have no more power, to annoy myself I have submitted myself, with gecko g540 I worked already 4 years , and never the driver worked well.
 I know that someone will say (This guy just does not know how to set the cnc machine!) This is not true! , For 4 years there is no possibility, so you did not learn what's come on in this.
Is there any problem, but I do not know what , and the worst part is that no one know what the problem is
« Reply #3 on: October 19, 2011, 07:23:17 AM »
I want to check once more g540, so I decided to build this cnc router with 2 Z axis. the only problem I have is if I will be able connect the 2 Z axis separately
I mean 1 to Z axis and the second to A or to B  i dont know
« Reply #4 on: October 19, 2011, 07:34:16 AM »
what are you building, any why?... and I see that as a programming nightmare.
« Reply #5 on: October 19, 2011, 08:32:11 AM »
MACH3 only has 1 z axis. IF you want to build duplexed version you are on your own.
« Reply #6 on: October 19, 2011, 09:19:18 AM »
ok I see that there is no other option, it means I have to disconnect from one Z axis  motor cable , and connect the other motor. I am building a cnc router with plasma ,on one Z axis  will be plasma on the second Z axis spindle.
and that is why I wanted to work 2 Z axis separately.
does this mean? after working with plasma, machine will have to go to zero, rewarded the cables and start the spindle axis?
« Last Edit: October 19, 2011, 09:24:38 AM by komar1970 »
« Reply #7 on: October 19, 2011, 09:45:18 AM »
Then your not using a ROUTER your building a dual headed plasma cutting machine. That I would think you could do with one Z axis head and two digital height controllers. But your on your own with that.
« Reply #8 on: October 19, 2011, 09:54:34 AM »
Maybe you could create two separate profiles.
One for Plaz, and one for Rout.
Then you would only need 1 Z axis.
Just jog the one you are not using clear of the work area.
Possible ?
Russ
YNN,
  I think maybe you misunderstood.
"""I am building a cnc router with plasma ,on one Z axis  will be plasma on the second Z axis spindle."""
« Reply #9 on: October 19, 2011, 09:58:19 AM »
I mean 1 z per config.
Sorry for any confusion :)
