Hello Guest it is November 13, 2026, 08:05:46 PM
Author Topic: z not raising enough after cutting  (Read 11944 times)
« on: October 12, 2011, 10:49:48 AM »
I set my vcarve  to .3 and my mach3 safe z to .2 . It cuts the letter then move to the next letter and carves a .05 grove as it move to the next cut.
Anyone ever have that problem?
Re: z not raising enough after cutting
« Reply #1 on: October 12, 2011, 12:04:58 PM »
Depends on HOW you specified the safez to be in Mach3. Work height, Machine value or incremental move
But from here looking at your moves the safe Z is LOWER than the cut height.
Just a thought, (;-) TP
« Reply #2 on: October 12, 2011, 12:30:35 PM »
so I need to try setting my safe z higher?
« Reply #3 on: October 12, 2011, 01:22:11 PM »
Is it really Machs safe Z that is the issue? From what you are saying it sounds like its your code that the problem is with.
« Reply #4 on: October 12, 2011, 05:05:01 PM »
Safe Z should have no effect while g-code is running.
From the sound of things, you may be losing steps when the router is retracting. When it's cutting the .05 deep groove, what does the DRO show? If it show .3, then your losing steps. If it shows -.05, then your code is wrong.
