Hello Guest it is November 13, 2026, 08:06:59 PM
Author Topic: Configuring Mach 3 on new PC  (Read 14792 times)
« on: October 11, 2011, 07:58:22 PM »
About 9 years ago, I built a CNC Router and had it up and running on Master5. Ran rather nice. The machine went into storage for a while, family used it, yadda yadda. I just finished rebuilding it (I made a lot of noob mistakes first time around) and I bought an "off-lease" PC from Tiger Direct. I wanted to use Mach 3 to set up the machine this time around, but to be honest, I have no clue where to start. Port settings, inputs, outputs and motor tuning? WTF did I get myself into?!?!?!?
As I mentioned, this was a full 9 years ago. I "think" I can scrounge up the old PC and maybe hopefully pull the settings off of that. Would this work?
If I need to start from scratch....oh boy, this oughta be fun.....
Little info:
I can't quite recall the makes and models of all the itmes used but what I can recall is this much:
Keling 72 VDC power supply (yeah, 9 years ago, I thought that bigger was always better)
No name BOB. Simple PCB with one whole strip of terminals on it. Currently, there are only 6 wires coming off of it headed to my:
Geckos. Not quite certain what version they were. I bought those used from someone on Art's forum that he had back then.
If it ain't broke, modify it!
  •  9,377 9,377
Re: Configuring Mach 3 on new PC
« Reply #1 on: October 12, 2011, 01:19:39 AM »
May I suggest you do a bit or reading first http://www.machsupport.com/docs/Mach3Mill_Install_Config.pdf then ask questions on the bits you don't understand. This should be the quickest way to get it sorted as most questions here are answered quite quickly but you need to ask specific questions.
Hope this helps,
« Reply #2 on: October 12, 2011, 03:19:28 AM »
oh, wow. very nice. thanks! hmmm, wonder if my printer has enough ink for 106 pages......., lol
  •  9,377 9,377
« Reply #3 on: October 12, 2011, 04:18:36 AM »
Yer don't print it all, just the setting up bit Chapter 5 (I think)  ;D ;D
« Reply #4 on: October 12, 2011, 04:55:48 PM »
Yeah, but I'm a machinist IRL, and there are times when I am sitting at my machine twiddling my thumbs... Would be nice to have something prosuctive to leaf through
« Reply #5 on: October 12, 2011, 08:51:38 PM »
hmm....... try rotating the thumbs in opposite directions, takes practice and time goes quickly..... ;) :D ;D ???
« Reply #6 on: October 12, 2011, 09:04:11 PM »
NOPE just print the manual a few pages at a time . EVERY day print a few more. That will fool you  into thinking you saved ink
(;-) and SPREAD OUT the reading time to make it last.
Ya got it bad, (;-) TP
« Reply #7 on: October 13, 2011, 02:04:34 AM »
Or buy the printed copy, its very nice quality and very reasonably priced.
« Reply #8 on: October 15, 2011, 04:01:01 PM »
made a new thread to detail the issue I am dealing with.
