Hello Guest it is November 13, 2026, 08:00:03 PM
Author Topic: homed axis (XYZ) DRO does not read zero  (Read 14193 times)
Offline geone
  •  23 23
« on: October 11, 2011, 01:13:00 PM »
Can't seem to get it right:
I referenced all and the machine completed as expected, however, the DRO are not showing zero.  I cannot figure out how to get them to read the home value.  I am trying reference the machine so the cutting area can be moved away from the home(s).  I am expecting the DRO to read zero on all axis.  Yes?
thanks
geo
Re: homed axis (XYZ) DRO does not read zero
« Reply #1 on: October 11, 2011, 01:28:38 PM »
Only when you are viewing the machine coords will you see the axis zero when you home, normally you are viewing the offset coords.
If you are viewing Machine Coords and when you home they dont zero then likely you have a Home Off value set on Homing and Limits page.
« Reply #2 on: October 11, 2011, 01:41:02 PM »
DO you have the auto zero checked for homing or are you using a home offset value OR are you using the set values for G28?
If you look in the Mach3screen reference manual on page 23 it shows the options you can choose to use to setup the home positions. There are many(;-)
Just a thought,(;-) TP
Offline geone
  •  23 23
« Reply #3 on: October 11, 2011, 02:28:02 PM »
I pulled the trigger too quick...I reread the manual and as you indicate, user error...set the auto zero and all is well
sorry to take valued support time..
thanks mucho
geo
Offline alenz
  •  137 137
« Reply #4 on: October 11, 2011, 10:45:04 PM »
TP, where do I find the Mach3screen manual? I have downloaded, printed and bound most of the Mach manuals, but I guess this one slipped by me.
Al
« Reply #6 on: October 12, 2011, 08:46:23 AM »
There is also a gcode reference manual and a sorted OEM functions manual out there if youdon't have it yet
Offline alenz
  •  137 137
« Reply #7 on: October 12, 2011, 07:58:25 PM »
