Hello Guest it is November 10, 2026, 05:15:41 AM
Author Topic: Timer with analogical inputs  (Read 26458 times)
« on: October 10, 2011, 07:25:39 AM »
Hi.
I need a way to read in Mach3 the value of DSPMC card time when the analogical input DRO has updated.
I need to have in Mach3 not only the value of analogical input, but also WHEN it was red by DSPMC (and not the time when Mach3 had received it, because it should be not the same, and it should depend by buffer ...).
And more, in the guide of DSPMC I find that frequency of analogical inputs is 10kHz. But also if I read up to 8 inputs, frequency is the same, or I must divide the max value of frequency by the number of inputs reading together?
Thanks for your help!
