Hello Guest it is November 13, 2026, 08:10:04 PM
Author Topic: Not accurate at high speed  (Read 9041 times)
« on: October 07, 2011, 07:04:28 AM »
Hi, i have made myself a CNC-router to cut in wood. It has a rapid of 2500mm/min. The problem is that if i try to cut at these speeds it makes a the sharp edges of my object round. It doesn't reach the corners of my project... I can hear that the steppers isn't loosing steps, they sound just fine. If i cut at lets say 500mm/min, it reaches the edges everytime. Is there a parameter in mach3 that is set wrong or are my acceleration to low? I just thought mach3 took the acceleration in consideration when cutting?
I can't quite figure this one out on my own, and my guess is that it's just a simple thing that some of you bright minds know everything about :)
Regards Nic
Re: Not accurate at high speed
« Reply #1 on: October 07, 2011, 07:24:50 AM »
Hi Nic,
   Read throught this :  http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
It should answer most of your questions on this subject.
Russ
« Reply #2 on: October 07, 2011, 09:42:21 AM »
Very nice!
Thank you Russ!
