Hello Guest it is November 13, 2026, 07:58:17 PM
Author Topic: G28.1 - some more help pls  (Read 9173 times)
« on: October 07, 2011, 01:38:10 AM »
I use G28.1 x0y0z0 in the genral seting window, so the machine to init all axis when powered on.
BUT, it firts inits X and Y and finally Z.
HOW to force the sequence to init Z first?
Also the GOTO ZERO buton does the same. I wish when I push it, Z axis to be the first to go to zero.
Otherwise some damages can occure.
Please adwise!
Re: G28.1 - some more help pls
« Reply #1 on: October 07, 2011, 01:10:10 PM »
What code would you use IF you just wanted the Z to rehome???
Now what code would you use IF you wanted X or/and Y to refhome???
What was the question again?
« Reply #2 on: October 07, 2011, 06:14:17 PM »
You need to turn on Safe Z in order for the Z to move first with Goto Zero.
