Hello Guest it is November 13, 2026, 08:25:16 PM
Author Topic: malfunction in toolpath  (Read 9595 times)
« on: October 05, 2011, 10:20:08 AM »
 I have a problem when running a 3d tool path, it goes just fine then for no reason it will move the starting point. And then the project is just a scrap of lumber, has anyone else had this problem?
Re: malfunction in toolpath
« Reply #1 on: October 05, 2011, 10:34:13 AM »
Can you attach our xml and also the code you are having issues with and say roughly the line number in the code where the problem appears.
« Reply #2 on: October 05, 2011, 10:37:48 AM »
Sounds like your machine is losing steps and losing position. Try lowering the acceleration by 50%.
