Hello Guest it is November 13, 2026, 08:06:53 PM
Author Topic: superpid control under mach3  (Read 15511 times)
Offline dude1
  •  1,253 1,253
« on: October 02, 2011, 08:52:10 PM »
does anyone now what config to use for the superpid running mach3 through a g540
can get spindle to turn on and off but cannot seem to change the speed of the spindle in mach 3 help please
Re: superpid control under mach3
« Reply #1 on: October 02, 2011, 09:11:14 PM »
There's a huge SuperPID thread at CNC Zone with help from the designer.
http://www.cnczone.com/forums/diy-cnc_router_table_machines/112658-super-pid_new_low-cost_router_speed.html
Do you have a V1 or V2?
On Ports and Pins, Spindle TAB, do you have "Use Spindle Motor Output" and "PWM Spindle" checked? Do you have a pin setup on Motor Outputs for the spinde Step pin, which is used for the PWM?
Offline dude1
  •  1,253 1,253
« Reply #2 on: October 03, 2011, 03:08:23 PM »
i have v2 configed for mach3, i got all of that done i have wired it according to g540 wiring on page 25 on super pid instructions it is set up OK i think. it does 5000rpm or 30000 rpm only. when i calibrate spindle using auto cal it work perfectly
« Reply #3 on: October 03, 2011, 06:13:50 PM »
What works perfectly?
You can only calibrate the spindle if you have the tach input connected to Mach3. And it's not recommended to do that with the Super-PID, as it's not needed.
Try deleting the file linearity.dat in your Mach3\macros\yourprofile\ folder, then restart Mach3 and see if it helps.
If not, post your .xml file. You either have a Mach3 setup issue, or possibly a wiring or parallel port problem.
Offline dude1
  •  1,253 1,253
« Reply #4 on: October 03, 2011, 08:35:15 PM »
i found something on the cnczone that has worked
