Hello Guest it is November 26, 2026, 07:49:37 PM
Author Topic: file convertion  (Read 9189 times)
file convertion
« on: September 30, 2011, 02:29:21 PM »
Hi, i'm new in mach 3 ,normally y make the modeling in art cam jewelsmith and then to mill master, now i changed the machine and the controller software  and  when i click the file icon on mach 3 it only shows : load g code, lazycam,  and close file, nothing like DXF import window that  mach 3 mill tutorial shows, i got mach 3 with a cnc machine from uk and  the suplier guaranteed that mach3 is fully functional and fully licensed, am i doing something wrong?
thanks if somebody can help
Re: file convertion
« Reply #1 on: September 30, 2011, 04:09:18 PM »
What software did you change from and to?
Did you contact the supplier about the problem?
Can you post your xml file your using.
Re: file convertion
« Reply #2 on: October 01, 2011, 01:59:51 AM »
The video will be of the old way Mach did things, you now use LazyCAM if you wish to convert a DXF to code.
