Hello
Guest
it is
November 13, 2026, 08:29:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Adding a physical button to control outputs
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Adding a physical button to control outputs (Read 25687 times)
swanner
57
Re: Adding a physical button to control outputs
Reply #10 on:
October 03, 2011, 09:52:25 PM »
Thanks, that did it regarding how I want it to work but I'm still getting the bad xml message even after renaming the file...
Carnoustie, Scotland
Reply #11 on:
October 04, 2011, 01:36:16 AM »
Are you using the parallel port or some other external device? Do your choices of brains stick when you restart Mach or do you have to enable again? Can you attach your xml and I will see if I get that problem when I use it.
swanner
57
Reply #12 on:
October 05, 2011, 12:18:35 PM »
When I restart the brains are disabled, enabling them give that message but they work after. I'm connected to the controller via USB (Industry Controls MCB-1). See brain attached.
Reply #13 on:
October 05, 2011, 01:42:43 PM »
I run brains with IC and a Scorpion so IC is not the problem. Have you got version 4.01.030?
swanner
57
Reply #14 on:
October 05, 2011, 01:48:16 PM »
No, I have 4.001.031 - I updated the mach.exe file a few weeks ago when I was having issues with a dubious soft limit warning that I'm still have half the time.
Reply #15 on:
October 05, 2011, 01:50:18 PM »
Ah yes I remember.
Should be fine then, going to load your brain and see if it throws an error here.
Reply #16 on:
October 05, 2011, 01:53:48 PM »
Ok its 030 version I have here and its working fine in that, will see if I can get the 031 version from Brian and test.
Reply #17 on:
October 05, 2011, 02:22:08 PM »
Just loaded 031 and its fine for me, dont have a MCB1 so possibly that is the reason.
Print
Pages:
1
2
Go Up
« previous
next »
