Hello Guest it is November 13, 2026, 01:54:18 PM
Author Topic: Error returned from USB function FT_Write  (Read 17868 times)
« on: September 24, 2011, 01:16:08 AM »
Out of the blue, my smoothstepper quit responding and a pop up error
message says:
Error: FTDI USB Driver Error
Error=FT_IO_ERROR
Bytes requested: 192
Bytes written: 0
I changed the driver and plugin for SmoothStepoperUSBDriver2.0802 and Plug
in SmoothStepper_v17bd but I still get the same error after a whole.
I'm using win7 and never had this problem before.
Any suggestion?
Miros
Re: Error returned from USB function FT_Write
« Reply #1 on: September 24, 2011, 01:46:58 AM »
What are the state of the LEDs on the SS when Mach is started? Have you unhooked the SS from the USB (If using internal power) or the 5v supply (if using external power) and then reconnected?
« Reply #2 on: September 24, 2011, 06:36:51 PM »
I didn't explain well. When this error appears, I have to restart the PC completely, but then I lose the coordinates... I begin to cut once again and the error keeps coming you never know when and why... Sometimes it's like once a day, sometimes it's like every hour. I lose so much time.....
Thx for any suggestion.
« Reply #3 on: September 24, 2011, 07:16:27 PM »
Check in device manager that the USB root hub power option is not set to allow windows to shut it off, see pic.
Edit, just noticed you have W7 but likely it has a similar setting as XP
« Last Edit: September 24, 2011, 07:18:10 PM by Hood »
« Reply #4 on: July 23, 2012, 08:55:24 AM »
mirek, have you solved this problem? I am having this problem also. I am about to pull my hair! Wondering if the SS board is defective?
John
« Reply #5 on: July 23, 2012, 09:33:02 AM »
Yes, I had to change the interface (board).
« Reply #6 on: July 23, 2012, 10:00:24 AM »
Thanks for responding. I am not sure which interface board, is it the smooth stepper? I have just ordered some ferrite and line noise suppressors. I hope this helps.
John
