Hello Guest it is October 24, 2026, 10:08:17 PM
Author Topic: first run with mach3  (Read 34710 times)
Re: first run with mach3
« Reply #10 on: September 23, 2011, 07:50:35 AM »
dera tweakie
i already read the mach 3 mill install config before.I also instal and config follow them,but still can't get the right seting .
if you  don't run the mach .can u get 5 V at pin 3 and 25? if yes that mean my pc error .
or do you only have 5 V if just you run mach3 .if yes ,mean my seting mach error.
pls advise.
thank you.
  •  9,374 9,374
« Reply #11 on: September 23, 2011, 09:48:22 AM »
Hi Asen,
You need to run Mach.
On your PC, go into device manager and check the LPT parallel port address (usually 0378) then check this is the address entered in Mach.
« Reply #12 on: October 28, 2011, 04:50:53 AM »
dear Tweakie
I just try another smaller nema 11 ,yesterday the motor can run by jog with keyboard or DMG on srenn , but when I run use G0 command ,the motor run about 3/4 turn ,stop for a while ,then run again 3/4 turn ,stop ,then run again .
what is this cause from ?.
pls advise.
thank you
« Reply #13 on: October 28, 2011, 04:53:33 AM »
I also inform u ,
on the screen ,the DRO not runing fluently .(0-1,2-3-4-5 ) but this is jump ,( 0-1,1-2,7-4,3-5,9-7,5-9,1-----)
« Reply #14 on: October 28, 2011, 04:55:19 AM »
I try to exit the program ,then run use mach3 loader .then the DRO can run fluenly ,(0-1-2-3-4-5----)
but ,to day I run the program ,the DRO not stepp againt.
pls advise.
  •  9,374 9,374
« Reply #15 on: October 28, 2011, 06:04:37 AM »
dear Tweakie
pls advise.
thank you
Hi Asen,
My guess is that it is your PC.
If it is running background tasks or sharing application time like multi-tasking then this may cause the issue you are having.
« Reply #16 on: October 31, 2011, 04:23:16 AM »
dear Tweakie.
thank for yr advise,
I re install my pc ,and scan with anti virus ,dellete all un neseccery program ,re install mach 3, the motor run smoothly now,
in motor tunning , I set 200 , but unly 1/3 turn for 10 mm ,should I set this stepp per  to calibrate with the 3mm pitch ballscrew become higher ?
but yesterday ,4 turn in 10 mm .
pls advise
  •  9,374 9,374
« Reply #17 on: October 31, 2011, 06:04:08 AM »
Hi Asen,
You should be able to calculate your steps per unit of movement exactly for each axis that uses different pitch screws etc. This calculator may be of assistance to you http://www.machsupport.com/forum/index.php/topic,16315.0.html
« Reply #18 on: November 01, 2011, 08:50:03 PM »
dear tweakie
my stepp motor is 1.8 - step = 200 /rev .lead screw 5mm /rev . that mean stepper motor run 1 turn ,the axis move 5mm . .but where I must set this step  at mach3?.I set at motor tunning , step per set at 200 .but now ,the motor turn 2,5 turn for 5 mm .
yesterday when I start the pc, when I push the ALL REF HOME, all axis become 0 and the axis 's LED become green ,but to day can't move , but the z axis move to + .not going to 0 .
pls advise
thank you
  •  9,374 9,374
« Reply #19 on: November 02, 2011, 09:43:19 AM »
Hi Asen,
You also need to know how many "microsteps" your controller is set to.
As an example - I use 1/8 microsteps so...  200 steps per rev = 8 x 200 = 1600 microsteps per rev = 1600 / 5 mm pitch = 320 steps per unit
You need to get the steps per unit right, for your installation, before you proceed. Perhaps read the manual again, use Al's calculator mentioned previously to calculate the steps.
I fully appreciate the difficulties involved here, when I started it all seemed so daunting but once you have got a grip on this then it all falls into place and then just seems so simple.  ;)
