Hello
Guest
it is
November 22, 2026, 08:26:10 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
change machine direction of arrow controls on keyboard
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: change machine direction of arrow controls on keyboard (Read 11935 times)
geone
23
on:
September 18, 2011, 10:20:43 AM »
Is there a way to change the machine directional movement to match the arrow direction of the keyboard (jog only)
thanks
geo
Logged
Carnoustie, Scotland
Re: change machine direction of arrow controls on keyboard
Reply #1 on:
September 18, 2011, 10:29:19 AM »
You can change it from Config menu Then System Hotkeys. However it should be set right as it is the direction of the tool in the work that you should be thinking of rather than the table direction but entirely up to you if you feel the need to change
Logged
Tweakie.CNC
9,378
Super Kitty
Reply #2 on:
September 18, 2011, 10:30:55 AM »
There sure is.
Config / System Hotkeys is the place to go to make your choices but remember that the usual convention is that jog is tool direction relative to the work not table direction.
Hood beat me to it
Logged
geone
23
Reply #3 on:
September 18, 2011, 01:23:52 PM »
thanks for the info.....just an aside...my right arrow should move the X axis to the right (right)? they are just opposite now.
mucho grass
Logged
BR549
6,965
Reply #4 on:
September 18, 2011, 02:27:05 PM »
Just a note: it should move the TOOL to the right not neccessariily the table. It depends on what type machine it is as to which way it moves to be correct. For example Bed/Bridge mills are backwards to knee mills.
Just a thought, (;-) TP
Logged
geone
23
Reply #5 on:
September 19, 2011, 11:41:08 AM »
this is a router that I built...I have set the origin to the 0-0 at the front left corner (facing the machine). all other axis work as expected and now so does the X ... thanks again
Logged
Print
Pages:
1
Go Up
« previous
next »
