Hello Guest it is November 13, 2026, 04:47:34 PM
Poll
how to configure two modbus
Plugin
0 (0%)
0 (0%)
Total Members Voted: 0
Author Topic: Modbus Peter homann  (Read 16235 times)
Offline Cle
  •  1 1
Modbus Peter homann
« on: September 16, 2011, 01:09:50 PM »
I'm having some trouble with the second Modbus to getting it configure (see attachment).
 Any help would be nice Thanks,
Re: Modbus Peter homann
« Reply #1 on: September 17, 2011, 07:18:27 PM »
The problem appears to be that somewhere along the line, a change to Mach3 is causing this problem with the plugin, as it used to work fine.
As the plugin is no longer being supported the solution is to use the Mach3 brains instead of the plugin.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: September 20, 2011, 09:01:55 AM »
I mentioned this to Peter over a year ago when I was trying to get two MODIO's to talk together over RS485. The plug in does not work.
Have a good day.
« Reply #3 on: December 20, 2011, 07:00:42 AM »
Maybe this isn't the place to ask but does John Prentice's ModIO Plugin work as well as shown in the videos wilt ONE ModIO? It looks pretty neat if it does. Can it be configured to Peter's "0" default address and use analog inputs? If not I can use brains.
Tony
« Reply #4 on: December 20, 2011, 02:40:16 PM »
Hi Tony,
Yes it does. It work well with one ModIO. The problem is when tryiing to configure the 2nd one.
Cheers,
Peter.
Homann Designs
