Hello Guest it is October 24, 2026, 08:27:05 PM
Author Topic: tooltable trouble  (Read 61508 times)
Re: tooltable trouble
« Reply #20 on: September 20, 2011, 12:28:16 PM »
THe OTHER wizards are created by private individuals, they are the ones that you would need to contact for support.
 OR learn to fix them(;-)
Just a thought,(;-) TP
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #21 on: September 20, 2011, 01:48:22 PM »
It is only recently that users could read data from the tool table so the older wizards will not have this included in them.  If you load the wizard and do a button script edit you can amend the code to take advantage of the new features.
« Reply #22 on: September 20, 2011, 03:47:28 PM »
Loaded the Circular Wizard from Brian again.  The Button Editor doesn't bring up the Tool Number or Tool Dia. button/windows.  Like I said, not a major problem, just something to be aware of when working with Wizards outside of the New Fangled Wizards.   My  solution is to refer to a printed sheet showing which tools my tool numbers refer to so I can plug in the correct tool and their diameters in the Wizard.
Bob @ BobsShop
