Hello Guest it is November 13, 2026, 12:59:18 PM
Author Topic: Running G28.1 while in G68 Rotated coord base  (Read 7902 times)
« on: September 12, 2011, 01:49:36 PM »
HEY Andrew could you ask Brian if he could fix the G28.1 Z   so we could run it while in G68 Coord rotation. We only need the Z to be able to refhome in plasma NOT the X/Y. I understand the important of not being able to refHome X/Y while the G68 is rotated BUT that shold not effect the Z axis in any way.
It would be a great time saver for the plasma group IF they could use the g68 and still use the G28.1 Z.
Note: you can use the G68 IF you are using the G31 method of TOM.   Most use the G28.1 method(more dependable).
Just a thought, (;-) TP
