Hello Guest it is November 13, 2026, 01:00:12 PM
Author Topic: i need help in setting up the Mach  (Read 12386 times)
« on: September 11, 2011, 05:54:25 AM »
Hi
I need some help. I bought new machine with 3 axis. Also im new in  CNC. I face problem with the setting up my machine. After I start running the program(G code), in the middle the program is stop due to Estope. Is there any part I need to check. I was thinking that happened because I have the free copy. But already I bought the license.
I appreciate your support.
Re: i need help in setting up the Mach
« Reply #1 on: September 11, 2011, 09:16:22 AM »
Was there a message in the error bar?
« Reply #2 on: September 11, 2011, 09:23:38 AM »
Q alsayed,
1.First copy the license file to the folder where Mach3 was installed.
2.Post nformation about the cnc system you purchased.
3.Then at least look at some of the manuals.
« Reply #3 on: September 11, 2011, 09:57:21 AM »
Hi
thank you for replay
to Rich
i did no. 1, 2, 3.
the machine is from china. ( working travel  850,480,65.) stepper motor type (57 two phase  3A super-low noise)
spindle motor 0.8 kw  VFD spindle .
spindle speed 3000--9000 rpm
resetting accuracy 0.05
the massage error is external  emergency ...
i increase the Debounce Interval to 1500 but still after some time it is stop.
if i give sample job it is ok but if it is need cutting and pass more then one time i face the problem.
« Reply #4 on: September 11, 2011, 10:02:40 AM »
Likely either noise or crap switches, both common on Chinese machines I am afraid
Increasing the Debounce Interval more may help but really you want to probably sort out the wiring and properly shield and ground limits and possibly fit better limits if their quality is not great. Could also be the VFD as they can be noisy especially, again, the Chinese ones.
« Reply #5 on: September 12, 2011, 07:09:23 AM »
Hi hood
i check the wire it is ok
however, i try some think which i can not find the reason. my existing machine are running by windows 7. i change the machine and try to rub same file with other computer running by windows xp . it run with out problems. and it is old computer.
so how i can check the right computer suitable for the machine and program.
thank you.
