Hello Guest it is November 13, 2026, 05:45:20 PM
Author Topic: How to tell if the movement is occuring  (Read 8343 times)
« on: September 06, 2011, 02:04:41 PM »
I am working on a Plug-In (using plug-in wizard and Visual C++ 2008) and I am wondering what is the "best" or "proper" way  to find out if movement is occurring.  For example, I would like to use the Code() function to send Gcode such as "G01 X1 Y1 Z1", and then display a status indicator of "Moving" or "Stopped".  I found an example that compared Engine->TrajHead to Engine->TrajIndex and if they were different, the system was moving.  Is that the only way to determine if movement is occuring, or is there a property with a true/false value or some other way?
Re: How to tell if the movement is occuring
« Reply #1 on: September 07, 2011, 03:07:16 PM »
You can try to use this one: MainPlanner->ExternalStill
It is better ( compared to trajectroy variables) because in case of e.g. external motion plugin it should accomodate also jogging and homing ( which is not a part of trajectory planning)
« Reply #2 on: September 09, 2011, 03:55:54 PM »
Thanks for the suggestion, however MainPlanner->ExternalStill stays true even when movement is occuring.
« Reply #3 on: September 10, 2011, 08:40:25 AM »
Well, maybe it works only in case of motion plugins, not with embedded LPT support :-(
