Hello Guest it is November 23, 2026, 05:12:00 AM
Author Topic: Switching computer woes  (Read 24493 times)
Re: Switching computer woes
« Reply #10 on: September 01, 2011, 03:35:15 PM »
Set them all to 1
Offline bpimm
  •  22 22
« Reply #11 on: September 01, 2011, 03:46:02 PM »
Thank you Thank you Thank you, the motors are turning..  Just turning slow I'll check my setup.
 ;D
Brian
« Reply #12 on: September 01, 2011, 03:49:05 PM »
Good its going, still a bit concerned about the driver test though. What does the Time in Int and also the Frequency say on Diagnostics page?
Offline bpimm
  •  22 22
« Reply #13 on: September 01, 2011, 04:20:09 PM »
Here is a screen shot of the driver test.
Motor calibration is off, should it change from computer to computer?
Brian
« Reply #14 on: September 01, 2011, 04:24:32 PM »
Calibration should be the same if you use the same xml but unless you changed that xml it couldnt be the same one as no way the motors would run without you having the port numbers entered.
I am wondering if ossibly you need to run the driver test in compatibility mode? Never used Mach on W7 so not sure.
Offline bpimm
  •  22 22
« Reply #15 on: September 01, 2011, 06:36:36 PM »
time in Int is fluctuating between +3 and +4
Frequency is 25003
Brian
« Reply #16 on: September 02, 2011, 01:08:52 AM »
All is good then, it would seem its just the driver test itself that is not wanting to run correctly under W7, you could try setting it to compatibility mode but if the machine itself is running fine I wouldnt worry too much.
Offline bpimm
  •  22 22
« Reply #17 on: September 02, 2011, 09:38:58 AM »
Ok, I'm going to make some shavings today, we'll see what happens. Thanks for all the help Hood.
Brian
