Hello Guest it is November 25, 2026, 02:15:55 AM
Author Topic: getting no motion  (Read 55850 times)
Re: getting no motion
« Reply #30 on: September 05, 2011, 01:31:08 PM »
And if you put the Step active setting back to what you had previously do you still get this?
farmertwingolf
« Reply #31 on: September 05, 2011, 01:38:49 PM »
Do you mean the high/low setting or the step pulse in the motor tuning?
« Reply #32 on: September 05, 2011, 01:40:47 PM »
both
farmertwingolf
« Reply #33 on: September 05, 2011, 01:44:18 PM »
I believe my high/low settings are correct because I am able to get motion with step pulse at zero now. But I have tried the step and direction pulse on different settings. Seems to be consistent in getting off when changing directions.
« Reply #34 on: September 05, 2011, 01:47:17 PM »
Do the DROs show this out of position?
Attach your xml and I will have a look.
farmertwingolf
« Reply #35 on: September 05, 2011, 03:01:54 PM »
i noticed it was still on the wrong version. i went in and renamed the free version i had downloaded and think i set the pins, ports, inputs, and outputs the same as the wrong version, but getting no motion again.  i am close to pulling all my hair out.  here is the new xml that i am getting no motion from. thank goodness you have a lot of patience.
« Reply #36 on: September 05, 2011, 03:32:47 PM »
My patience ran out, must have been the long trip down the Clyde in the banana boat ;)
farmertwingolf
« Reply #37 on: September 05, 2011, 03:36:17 PM »
Oh. How did that xml look?
« Reply #38 on: September 05, 2011, 04:13:02 PM »
You can find whatever xml was working for you by going to the xmlsbackups directory of where Mach
is installed. You'll find a copy of the old xml file there.
farmertwingolf
« Reply #39 on: September 05, 2011, 04:25:42 PM »
The old xml file was the pirate one.  I have motion again with trial version. Still not moving the same in one direction as the other.  I am trying to set Y axis first.  It will move long in one direction and short in the other. If I get one direction calibrated the other direction has been off around .010
