Hello Guest it is November 23, 2026, 11:37:47 AM
Author Topic: Spindle timing/index  (Read 14190 times)
« on: December 14, 2006, 09:49:43 PM »
OK, I want to enable Mach3 to control my spindle on my mill using the feedback features. Right now I have speed control using one of cnc4pc's step/dir to 10v control boards. I also want to be able to stop the spindle at a certain spot so I can take advantage of the back face cycle. I plan on using two Keyence retrorefective fiberoptic sensors. The question is do I use both the index and timing inputs, or just index? I saw something in the manual about you can use multiple marks with index but one needs to be 50% bigger than the others. So that means the spindle will top at the large spot?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Spindle timing/index
« Reply #1 on: December 14, 2006, 10:12:44 PM »
Hi, Macona
I think the only way you could do this is to treat your spindle as an Axis, with an encoder.
Maybe I'm wrong, Chip
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: December 15, 2006, 02:58:53 AM »
My machine uses a latch.
I set up a macro to do spindle index.
I have to fire the solenoid, creep the spindle round and kill the motor when the switch on the solenoid triggers.  its a bit faffy to set up and get the timing right but when its set it works without a fault.
I use it for tool change index too.
I don't know how it would work with back bore cycle, I do them with long hand code.
Graham.
« Reply #3 on: December 15, 2006, 11:57:38 AM »
Thats not really going to work for me. I dont want to do any modifications to the head if I can get away with it. Plus I cant see anywhere to install something like that.
I went back to find where I saw something about using multiple marks in index mode and cant find it. Argh!
I guess I can give it a try and see what happens.
