Hello Guest it is October 01, 2026, 12:25:12 PM
Author Topic: Mach3 does not respond to jogging or running G-code  (Read 70627 times)
« on: August 26, 2011, 03:19:50 AM »
Hi all,
I am very new at this and hope that someone out there can help me with this little problem.
I have just installed mach3 on my computer running Windows XP. I have meticulously followed the instructions in the manual. I successfully ran the "drivertest" program. nevertheless, when I run the program and try to jog it or manually put in some G-code, the positions of the axis always remain at 0. Has anyone else come across this problem and found a solution? I would be glad to hear from you.
Adrian
Re: Mach3 does not respond to jogging or running G-code
« Reply #1 on: August 26, 2011, 03:24:38 AM »
Sounds like you have not got the axis enabled in Ports and Pins, Motor Outpputs, that is the only reason I can think of that the Readouts in Mach would not show movement.
« Reply #2 on: August 26, 2011, 03:30:46 AM »
Thanks Hood. Where do I find "Ports and Pins, Motor Outputs"?
« Reply #3 on: August 26, 2011, 03:31:34 AM »
Config menu.
« Reply #4 on: August 26, 2011, 04:03:49 AM »
Thanks Hood. That's done it!!
« Reply #5 on: August 26, 2011, 04:05:58 AM »
« Reply #6 on: October 03, 2011, 09:45:27 AM »
Hi All
I have installed Mach and gone thru all the setup done the driver test all ok when I try and jog I get movement on my screen but no output to my breakout board any ideas?
« Reply #7 on: October 03, 2011, 10:59:12 AM »
Most likely is the wrong port address, or wrong port # assigned to pins.
« Reply #8 on: October 08, 2011, 02:44:37 AM »
I do appreciate everyone's support with my previous problem. I am a bit further down the road to completion. However, I have struck another snag that is giving me headaches. When I send some G code to the controller, there is a high pitch sound from the stepper motors as though they are receiving pulses. However, there is no movement. I can control the stepper motors with a handheld controller and they move as they are supposed to. However, under computer control all I get is this high pitch noise from whatever stepper motor is supposed to be turning. Any ideas would be much appreciate.
Adrian
« Reply #9 on: October 08, 2011, 03:16:19 AM »
You would seem to have the Velocity and/or acceleration set to high for your particular setup and this is causing the motors to stall (high pitch sound)
