Hello
Guest
it is
November 13, 2026, 12:46:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Over clokking the speed
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Over clokking the speed (Read 22009 times)
Carnoustie, Scotland
Re: Over clokking the speed
Reply #10 on:
August 24, 2011, 05:03:25 AM »
Are you sure it is the plugin you installed rather than the driver as there should only be one dll and it will be called SmoothStepper_v17d.dll (if the latest one ) and yes it should be in the main plugin folder.
Logged
BasHIDAP
40
Reply #11 on:
August 24, 2011, 06:52:56 AM »
Thanks Hood, now it works!! If you install the m3p file, it moves the file to a different folder. I had to find it back en put it in the right folder. But then it worked well. Overclocking the speed is possible now.
Logged
Reply #12 on:
August 24, 2011, 03:46:42 PM »
Logged
Print
Pages:
1
2
Go Up
« previous
next »
