Hello Guest it is October 22, 2026, 06:46:04 PM
Author Topic: Passing Code to mach  (Read 14783 times)
« on: August 20, 2011, 02:43:03 PM »
When posting code in LazyCam somehow the code is passed to Mach if it is running on the computer. Anybody know how it is done? I have a custom application written in VB that creates code. I would like to pass the code to mach if it available. This is not a wizard but a stand alone app in VB.
Re: Passing Code to mach
« Reply #1 on: August 20, 2011, 08:54:00 PM »
HIYA Steve have the script write the Gcode as a text file then in the same script  LOAD the file into MACH and run.
OR do you mean run each individual line from inside the script 1 line at a time?
I should have examples of both ways here if you need them.
« Reply #2 on: August 21, 2011, 03:59:57 AM »
The program writes a Gcode file to "C:\program1.tap" but it would be alot easier if I could auto load the program into mach if Mach is already running.
« Reply #3 on: August 21, 2011, 07:02:57 AM »
Ask Brian on the Yahoo group.
Vectric's products (and others I believe) can also export code directly to Mach3. In Aspire there's a checkbox to  "Output direct to machine".
« Reply #4 on: August 21, 2011, 07:19:35 AM »
Thanks ger21
I had absolutely no trouble writing the code in VB to output to a file. I have been screwing around for 3 days trying to get it to work as a wizard. I can't find docs for the VB commands and can't figure out how VB works in Mach directly. Specifically the "code" command. I'm guessing the code command has something to do with loading commands into the code window.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #5 on: August 21, 2011, 07:48:32 AM »
With regard to doing this WITHIN Mach from a wizard or a macro take a look at Support/Mach Wiki at the top of this page.
In particular look at
http://www.machsupport.com/MachCustomizeWiki/pdfs/VB-Script-Commands.pdf
and
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach_specific_Subroutines/Functions_grouped_by_purpose
and look at "openTeachFile" in conjunction with "code".
With regard to sending code to Mach from an EXTERNAL app, SheetCAM amongst others do this - might be worth asking Les on the SheetCAM yahoo group.
Hope this helps.
Ian
« Reply #6 on: August 21, 2011, 08:21:56 AM »
So from what im reading I need to write the code into the teach file and then read it into the code window.
« Reply #7 on: August 21, 2011, 11:14:40 AM »
Steve another way ( simple to me) in your script
LoadFile("C:\program1.tap")
While Isloading()
Sleep(100)
Wend
RunFile()
OR the all in one method, but not always dependable to actually run on some puters
LoadRun("C:\program1.tap")
Just a thought(;-) TP
« Last Edit: August 21, 2011, 11:16:18 AM by BR549 »
« Reply #8 on: August 21, 2011, 07:40:48 PM »
Thanks.  I decided to go the wizard route so i'm up to my a$$ in that whole thing. I have the wiz producing code and running it. I just need to do small things like figure out how to turn on the jogging from the keyboard. I'm reading everything I can find on the web and in the wiki.
Thanks for all the help thus far.
Steve
